When you reset a device to factory defaults, you might create a network loop, depending on your network's topology. After you reset the device, make sure you re-deploy the network policy/template and any associated device-level configuration, and push a fresh update from ExtremeCloud IQ.Re-deploy the network policy/template and any associated device-level configuration, and push a fresh update from ExtremeCloud IQ.
